Machine Vision
VBAI 2018 on CVS - start inspection when launched
I select and switch inspection on CVS via step "Select Inspection". Is there any possibility to save my last option for next startup (booting CVS) ?
BR
j.
(2,189 Views)
Hi J,
When running Vision Builder AI on your desktop, open Tools>>Options and select the Startup Category. You can select to launch an inspection automatically when Vision Builder AI launches.
If you target a CVS with Vision Builder AI, open Tools>>Remote Target Options and select the Startup Category. This way, you can select to launch an inspection automatically when Vision Builder AI launches on the Compact Vision System.
You can also use the Switch Inspection step to change the inspection files on the fly.
Warm Regards,
Alejandro Balma
(2,141 Views)
Dear Alejandro Balma,
I have selected INSP1 in startup.
I use the Switch Inspection step to change the inspection files during inspection. I need to replace inspection file in startup to new inspection file when "Switch Inspection step" is done.
BR
J
(2,131 Views)
