Machine Vision
Variable height image acquisition using line scan camera Basler 6144-16gm, with software trigger
I'm developing prototype of an inspection system which will acquire variable height images using a line-scan camera. Frame-start and frame-stop actions to be controlled by software triggers. Maximum image range will be 12000 lines.
Setup details:-
Hardware components:
Camera -> Basler raL6144-16gm
NIC -> DGS-1008A
Software components:
LabVIEW 2014 (32-bit)
NI Vision Development Module 2014 (32-bit)
Basler Pylon Viewer ver6 (64-bit)
Windows 10 (64-bit)
Tasks:-
1. Configuring Frame-start and Frame-stop with software trigger in IMAQdx and  LabVIEW.
2. Configuring dynamic frame size (in length direction) for line-scan camera, i.e. variable height acquisition (VHA) with IMAQdx.
3. Memory allocation or buffer configuration for dynamic frame size images of line-scan camera.
4. Guidelines for configuration of line-scan camera parameters, and selection of related hardware components (such as lenses, lights, cables etc.)
5. Calibration of line-scan camera system.
I'm quite new in the field of machine vision and still learning basics of  concepts of line-scan camera system. Please share insights, tips, tutorials, study material, etc. Help and guidance of any sort is appreciated.
Thanks in advance.
B. Sharma
(957 Views)
Thanks in advance.
Regards
(911 Views)
