03-21-2016 05:02 PM
Is a license needed for vision acquisition and vision development functions running on a real time target?
03-22-2016 09:58 AM
Hello nanocyte,
Deploying a real-time vision application to a real-time target does not require a vision deployment license if you are deploying to a Smart Camera, Compact Vision System, or cRIO. The development machine will of course need to have a valid license for Vision Acquisition Software (VAS), Vision Development Module (VDM), LabVIEW Real-Time Module, etc.
j_bou
03-23-2016 04:03 PM
Are there certain NI targets where a deployment license is required?
03-24-2016 08:01 AM - last edited on 11-20-2024 08:13 AM by Content Cleaner
Hello nanocyte,
As a rule of thumb, if you will be deploying to a target which is running on a Windows OS, then you will need the vision run-time engine. If you are deploying to an NI target running a real-time OS, then no vision run-time is required.
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA03q000000YHVOCA4&l=en-US
What hardware are you planning to use? If you provide me with some additional details regarding your application I may be able to give you a more precise answer tailored to your particular situation.
Best Regards,
j_bou
