12-15-2016 12:49 PM
Hi
dear members i am working on egg crack detection . i have done finding the crack by using many ni forum member's suggestion its was helpfull. now i again need your suggestion for selecting the camera.
camera should be
autofocus , high resolution so that it can capture hair level crack, will be visible on picture , and also can connect with myrio (like usb 2.0 cameras ) , (any other specification if you think it should be in camera for small crack detection) .
your suggestion will be appreciated and i will be thankful to you
12-15-2016 04:00 PM
You should try Dark Field illumination for Cracks.
12-17-2016 07:09 AM
Dear amitshachaf
can you please elaborate this ?
12-17-2016 03:11 PM
Most importent factor for detecting cracks are usually illumination.
Dark field illumination is usually very effective for crackes.
You should experiment with that.
Camera resolution is usually less of a factor. Look on the links and see how effective is Dark field illumanation on cracks
I will direct you to couple of links.
1. NI Prectical guid for illumination.
http://www.ni.com/white-paper/6903/en/
2. Dark field illuminator from microscan
http://www.microscan.com/en-us/products/nerlite-machine-vision-lighting/dark-field-illuminators
3. Pdf at
4.
http://www.iimag.eu/en/lumimax/led-lighting/led-dark-field-illumination.html
01-06-2017 07:49 AM
01-07-2017 11:11 AM
dear hatef
myrio is supporting any usb camera
crack will of hair level small thinkness and depth will be like diameter of hair .
what's your opinion now
01-11-2017 12:49 PM
