04-26-2016 09:57 PM
hello master:
as i knew, the unit of coordinates of center return by "Pattern match" is "pixcel" in image. but actually we may send coordinate with "mm" or "cm" unit to robot in application. my question is how to transorm the coordinate from "pixcel" to "mm" or "cm". is there any master could give me information or example on how to do it?
thank you very much in advance.
thanks and best regards
viming.chen
04-27-2016 01:59 AM
any help?
05-02-2016 03:05 AM
You can directly map the pixels to your measurement cordinates. Can you physically measure how much mm your object is and see the corresponding pixels in the image.
05-11-2016 06:09 PM
09-16-2016 09:08 PM
sir, how to do it? now i have a application to do like this:
a PCB on the position of production line, use Camera to postion it and tell the robot coordinate to fetch it out? i know how to pattern match, but i don't know how to translate the coordinate that we got from pattern match to the coordinate which Robot use.
thanks.
09-16-2016 09:09 PM
how to calibrate the image first ,sir?
09-16-2016 11:22 PM
09-17-2016 04:33 AM
hello sir:
thanks for your reply. i had read some information about the calibration. but i don't know how to calibrate step by step with "NI Calibration training interface" . would you like to give me a sample or example on this topic? thanks you very much~
09-17-2016 05:31 AM
there is many example for this request inside NI example
check these bellow
09-17-2016 05:32 AM
also check this
