Machine Vision
coordinate transform--robot
Hello sir:
Regarding "Simple Calibration.vi", i had a question:
why they use "0.15" for "IMAQ set simple calibration2 vi"? it mean 1pixel=0.15Millimeter? but actually i got 1pixel=0.083Millimeter from picture's resolution. i don't understand these relationship. is there any help? thanks.
Message 11 of 34
(2,384 Views)
Message 12 of 34
(2,386 Views)
Time_Walker 已写:
Hello sir:
any help?
Message 13 of 34
(2,372 Views)
Yes, based on your image setup and calibration grid image it can vary.
-Yes it means one pixel is equivalent to 0.15mm in X direction and 0.15mm in Y direction
uday
Message 14 of 34
(2,371 Views)
udka 已写:
but actually i got the result from picture's resolution :
the resolution for picture is 300dpi. it mean 300pixels/inch, 1inch=25.4Millimeter.
300pixels/25.4Millimeter.
1pixel=0.083Millimeter.
why it is so huge different with "0.15mm" specified in picture? "0.15mm" is an arbitrary setting for demostration? when we need to set "X step", "Y Step" parameter in application, how to caculate it and set it?
Message 15 of 34
(2,366 Views)
you have to use sample target in your image that you know the dimensions of this sample
Message 16 of 34
(2,346 Views)
one more questiion:
X Step and Y Step:
"Scaling factors are the real-world distances between the dots in the calibration grid in the x- and y- directions and the units in which the distances are measured. Use the X Step and Y Step elements of the Grid Descriptor control to specify the scaling factors." this is the definition in "https://zone.ni.com/reference/en-XX/help/370281M-01/nivisionlvbasics/perspective_and_nonlinear_disto..."
the following is the definition in the labview help for "IMAQ Calibration Target to Points - Circular Dots VI", "X Step corresponds to the width of a pixel in real-world units." it make me completely confused.
Any help ? which one is right? Any official explaination? thank you very much ~~~~
Hatef.fouladi 已写:
Message 17 of 34
(2,328 Views)
witch part confused you?
Message 18 of 34
(2,301 Views)
Hatef.fouladi 已写:
X Step and Y Step:
The definition for X-step and Y-Step are the same? or they are different? i marked it with red color~
Message 19 of 34
(2,298 Views)
Accepted by Time_Walker
sppose you have two point  with distance of 1 cm
you  find out that this two point distance is 3 pixcel in image
so if you check bellow image you have this
x step 1
y stem 0,98
unit :cm
Message 20 of 34
(2,283 Views)
