03-08-2010 08:52 PM
I am doing a simple programming using Labview 2009. May I know anyone no how to remove background from the image? The programming is using camera. First, it show the image...then threshold it into white and black...then when the 'wanted' image has detected it will save the image...however, my problem is the image cannot be analysis due to the background is in green colour...so, I only want the object..fyi, the user want the image to be in RGB and the user need the background to be black but the conveyer is in green...we don't want to change the conveyer due to expensive and using sensor.
03-08-2010 10:57 PM
03-08-2010 11:07 PM
03-08-2010 11:10 PM
03-08-2010 11:17 PM
03-09-2010 12:26 AM
03-09-2010 12:57 AM
03-09-2010 05:26 AM
03-09-2010 07:55 AM
03-09-2010 08:03 AM
