03-10-2011 03:34 AM
Hi!
I have just started using an Edmund Optics CMOS camera (EO-1312m monochrome 1/2" sensor) in a project, whereas I have used a Logitech webcam until now. I have had no problems like this before I introduced the new camera.
The thing that happens is that, quite randomly, the image acquired appears mirrored on screen. Thereby rendering the rest of my image processing useless, since I then calibrate and use pattern match on a mirrored image.
I urgently need to find out what is causing this!
At the moment I am using the IMAQ functions and Directshow drivers to acquire the image, but there is a LabView package included with the camera. Maybe this has better control over the acquisition process?
Any input is greatly appreciated!
03-10-2011 07:20 AM
It seems I probably have a problem with the y scale orientation. I understand that some images have their origin in the top left corner and some have it in the bottom left corner. But how can this be so inconsistent for me? Does it matter in what format I have created the image, such as unsigned (U8) or signed (I16)? I need to lock this setting so that the image appears in the same direction each and every time.
03-10-2011 04:31 PM
ssuming you didn't change the "vertical mirror" attribute that we expose for DirectShow cameras, any flipping of the image is likely due to a setting within the EO driver itself. It is possible that using some of their apps might change this setting in a way that persists when you use it with NI software. Since we don't have any knowledge of that custom flipping functionality, we assume the default, standardized image ordering (the "mirroring" in our software simply changes. the line order we copy the data from the camera). You'd have to explore the settings that EO's software provides to see if you can somehow figure out why it was changing.
Eric
03-11-2011 06:10 AM
I got it!
In registry editor, under HKEY_CURRENT_USER\Software\IDS\uEye\DirectShow\Device1\Settings\UI154xSE-M\ImageSize, there is a value set for orientation of the image. I believe this is controlling the aforementioned setting in the Directshow driver. I am not quite sure what caused the unexpected random behaviour of this value, but I can simply set the value in my VI in LabView so that I know the image is acquired correctly every time. Problem solved, as far as I am concerned.
Thanks for the input:-)
08-18-2016 09:30 AM
I'm having a random 180 image rotation each run. Can you describe what is the registry key type and value you used please?
08-18-2016 11:47 AM
08-19-2016 01:25 AM - edited 08-19-2016 01:27 AM
See attached snip. It may appear that I have some more features available here than you do, or did you simply not expand the 'UI154xSE-M3' folder? Did you install the driver package for the camera?
Also, if you find it, the value should be 0. I simply made a VI setup in LV that writes value 0 to this registry key every time the test is run.
Kristian
08-20-2016 11:20 AM - edited 08-20-2016 11:21 AM
Thank for you quick respond. I think I expended the UI228... folder and there is nothing in it. I'll have a look at it gain next week when I return to office.
I installed only the EO-5032M driver bundle and I'm using IMAQdx and property nodes to grub and control the camera properties and not don net blocks. Other then the horizontal random flip the program works nicly.
Shai
08-22-2016 06:14 AM
Which product version of IDS uEye DirectShow do you have installed?
I checked and I am running version 3.82.
A few years have gone now since I worked with this, but I think I remember fiddling about with different versions of the SW before I found the one where I had full control over the necessary variables.
08-28-2016 03:36 AM
