01-25-2016 05:26 AM
some camera support different mode of fps and resolution for example 30 fps 300*400 / 25 fps 600*800 15 fpc 1200* 1800
when you call a camera with imagdx the default one start to act if you want to switch to different mode of camera you have to change the mode
labview example have a example of reading a camera mode and setting the option try to test it
01-25-2016 02:10 PM
01-25-2016 02:13 PM
Una iluminación adecuada permitirá resaltar las características de interés del objeto, reducir la complejidad de la imagen y mejorar el tiempo de respuesta del procesamiento digital. Existen variadas técnicas de iluminación, aquellas que funcionan correctamente en el laboratorio pueden no hacerlo al momento de ser usados en el campo industrial, a continuación los principales tipos de fuente de Luz
https://decibel.ni.com/content/docs/DOC-31879
01-25-2016 02:16 PM
12-07-2016 03:14 AM
Hi Hatef
my GigE camera support three modes of fps and resolution for example 250 fps 640*480 / 488 fps 640*480 1076 fps 256* 256, the system calls a camera the default one (250 fps 640*480) start to act, I want to switch to different mode.
I have tried IMAQdx Enumerate VIdeo Mode to set the height and width, but it cannot works. Also, the IMAQ video out display mode only have 640*480、800*600 and high resolution which I don't need.
So do you have any suggestions for change the camera mode?
12-07-2016 03:33 AM
