Machine Vision
nivision library - imaqMakeRect : access violation writing location
 I'm writing an image acquistion script using the nivision and niimaqdx libraries in python 2.7 using ctypes. When I use the function imaqMakeRect to make a Rect structure to use in the imaqImagetoArray function, I get an access violation writing error.
This is the line causing the problem - imaqMakeRect(c_int32(0), c_int32(0), c_int32(0x7FFFFFFF), c_int32(0x7FFFFFFF)).
resulting in the error : WindowsError: exception: access violation writing 0x00000008
The access violation location seems to depend on the value of the first argument. Any ideas about what might be going on ? and how to fix it ?
Thanks !
Message 1 of 9
(4,809 Views)
this 0x7FFFFFFF means that you overflow maximum possible number 4294967296
it limit your access of memory
Message 2 of 9
(4,796 Views)
But, I get the same error regardless of the value that I use there, even if it is less than 0x7FFFFFFF
Message 3 of 9
(4,790 Views)
access violation writing 0x00000008 error
accrue when you try to use part of memory that other program of process is using that part of memory and it is busy
Message 4 of 9
(4,788 Views)
I see. How do I avoid this error ? Its very reproducible.
Message 5 of 9
(4,786 Views)
Without posting any of your code it is impossible to know what the issue is, but it would seem likely that you are not wrapping the C functions properly in Python. A quick Google shows that someone has already wrapped NI Vision in Python:
https://github.com/robotpy/pynivision
Maybe try this wrapper code instead?
Eric
Message 6 of 9
(4,775 Views)
Even these three lines here reproduces the problem :
from ctypes import *
imaq = windll.nivision
IMAQ_NO_RECT =  imaq.imaqMakeRect(c_int32(0), c_int32(0), c_int32(100), c_int32(100))
Message 7 of 9
(4,773 Views)
I'm no python or cytpes guru, but this above example doesn't seem like it would be defining the function prototype for imaqMakeRect properly. SInce the functions are exported from the DLL as undecorated C functions, Python has no way to know the calling convention or the return value type. I'd imagine you'd have to specify a more complete function definition to make this work properly. Specifically, imaqMakeRect returns a structure, not an integer, and this may be the issue you are seeing.
I highly suggest looking at an existing wrapper like the one I pointed to that already does the wrapping for you.
Message 8 of 9
(4,768 Views)
Accepted by MIT20
Thaks for the suggestions !
This fixed it -
class Rect(Structure):
    _fields_ = [
        ("top", c_int32),
        ("left", c_int32),
        ("height", c_int32),
        ("width", c_int32),
imaq.imaqMakeRect.restype = Rect
Message 9 of 9
(4,764 Views)
