Machine Vision
pattern matching qeustion: when camera is not perpendicular to the object
Dear all,
i m new in NI vision. I have already created a program to do pattern matching, and hope to obtain the rotation angle.
my problem is: when  the object rotates in any angle greater than about 20°,  I cannot get an accurate angular measurement.
I assumed that it might because my camera was not perpendicular to the surface of the object. could any of you nice guys give me some advices,please.
thanks in advance
(3,850 Views)
Hi
Post your image so that give you a best practices.
Silver_Shaper | CLD
(3,843 Views)
Hi, Sasi.B
the arrowheads will point to certain direction. I hope use the template to obtain a rotation angle, but as you can see the match info could not provide a reliable angular measurement.
i have no idea how to get the direction now, the camera is fixed, does it mean that pattern matching is not a good choice in this situation?
thanks for your time
(3,836 Views)
Accepted by yhs
Just use the arrow as a generic object.  Place a fiducial make inside it, and find the relation between the arrow and the fiducial.  I edited your pics to place a hole in the top of the arrow.  The VI finds the arrow as a bright object.  It uses the bounding box as the search region to find the hole.  The center of the arrow and the center of the hole form a line that points in the same direction as the arrow.  The VI and sample images are attached.
(3,798 Views)
Hi, lcady
thank you very much, i didn't think about modify the template, this is really what i need
again, thanks for your time, have a lovely day.
yhs
(3,786 Views)
