11-22-2016 02:32 AM - edited 11-22-2016 02:32 AM
I have a question about FFT image via NI vision.
I've a programm in C#, which use NI vision, and a camera which are displaying an image on a human-machine interface.
My HMI displays also an FFT image of an ROI in the image camera. But i have a problem with this FFT when I define a "small" ROI (with a drag and drop). Indeed, the FFT image show a pixelized image like what we see in this image "bug FFT.png". But this problem appears not at all time, I think it appears only when I define a new ROI (If I use a predefined ROI, so not with the drag and drop method, and I load the same ROI at different point, there is a bug only when I change the ROI)
I dont' know why this "small" ROI is a problem, is there someone who have an explanation? An idea? Is the drag and drop event the problem?
11-22-2016 05:56 AM
11-22-2016 08:16 AM
Why not, but when I use 2 types of FFT for the same image:
- the first, classical FFT, has no problem with the ROI.
- the second is an average FFT, and the problem only appears with this average FFT.
The difference between the two is the size I think, because my Average FFT is an average of 5 images.
11-25-2016 02:24 AM
_imageCount = value; _imageCountFactor = new PixelValue(1 / (float)_imageCount); var LastImage = RefreshBuffer(NewImage); NationalInstruments.Vision.Analysis.Algorithms.Subtract(_buffer, LastImage, _buffer); NationalInstruments.Vision.Analysis.Algorithms.Multiply(_buffer, _imageCountFactor, _buffer); NationalInstruments.Vision.Analysis.Algorithms.Add(Sum, _buffer, Sum); LastImage.Dispose();
