07-03-2014 06:22 AM - edited 07-03-2014 06:24 AM
Hello guys
I am facing problem while thresholding 16 bit unsigned raw image. I am attaching my VI and snapshot of VI, along with this can you please let me know how should we get the intensity values under the ROI box after drawing ROI over image.
I will appreciate your help
07-03-2014 06:43 AM
As you can see you have not defined "16 bit greyscale (greyscale u16) for the imaq create of the threshold function.
07-03-2014 06:50 AM
Connection was there but I saw some sample Labview program and changed it. Now its totally back image is there, I also changed display pallete to binary
07-03-2014 06:52 AM
is the roi a one one roi or you will want to change it multiple times?
07-03-2014 06:53 AM
Can you post your 16 bit image?
07-03-2014 06:53 AM
For the constant ROI
07-03-2014 06:59 AM
Forum is not allowing me post RAW image. Its saying not a valid formate to upload
07-03-2014 07:03 AM
You can use iva histogram where you can define the roi
07-03-2014 07:09 AM
Try this for dynamic ROI
07-03-2014 07:22 AM
I appreciate your help .
In ROI program after taking ROI how could we get the values inside ROI matrix in the form of array . In my previous program I tried to convert the values coming from wire after the taking ROI but it doesn't show or come up in the form of matrix.
