04-05-2017 11:27 AM
Imperx IPX 1M48 L camera with a framegrabber of Teledyne dalsa X64 CL iPro.
We do not have support for your frame grabber. We only support National Instruments frame grabbers. You will not be able to use a Teledyne Dalsa frame grabber in MAX.
04-11-2017 12:15 AM
Thank you.
04-11-2017 01:22 AM
I faced a similar problem like the one you shared with the community. I searched a lot on google and at last found the solution to the problem on this site. Emergent VisionTec have the best on site solutions to problems people usually face while using machine vision cameras.
10-11-2019 05:28 AM
Hi, I hope you're fine.
I'm facing the same issue but not solve by renaming "niu3v". Figures have been attached. USB-cam has shown in NI MAX and properly work but not working in NI-IMAQdx devices.
