04-27-2005 08:37 AM
04-27-2005 09:19 PM - edited 04-27-2005 09:19 PM
Message Edited by Ancle on 04-27-2005 09:28 PM
08-28-2007 06:08 AM
08-28-2007 09:34 AM
08-28-2007 10:44 AM - edited 08-28-2007 10:44 AM
Message Edited by Lamas on 08-28-2007 10:48 AM
08-29-2007 10:01 AM
04-04-2011 03:31 PM
Hello there... I have used the attached VI in order to convert an RGB image into Grayscale but i found that i have to retrieve an image that is saved on my hard disk. My question is that if i was able to capture an image using a webcam, how can i directly convert it into grayscale? is it possible to do the conversion without the need to save the image like the attached VI shows?
Regards...
07-08-2014 11:00 PM
I made a modification to the VI. It can convert 32, 24, or 8 bit images to grayscale. However, it doesn't change an image from 32 or 24 bit to 8 bit. I know this is an old post but maybe this will help someone.
Chief LabVIEW Architect, Testeract | Owner, Q Software Innovations, LLC (QSI)
Director, GCentral | Admin, LabVIEW Wiki | Creator, The QControl Toolkit
Certified LabVIEW Architect | LabVIEW Champion | NI Alliance Partner
07-09-2014 01:13 AM
Can you try extracting a single plane ?
07-09-2014 07:55 PM
Not sure what you mean by extracting a plane?
Here is a VI that will convert an image to 8-Bit. This paired with the grayscale one will get the desired result. See example.vi below. Order that they are applied does give slightly different results.
