05-09-2022 12:14 PM
I want to do a triggered acquisition from our new e2v octoplus (camera link model). I have it connected to a PCIe1433 board. It needs to be synchronized to a TTL trigger (from a DAC controlling galvo mirrors). That triggering model works for another camera.
With the octoplus I can set the camera to external triggered acquisition mode (using the serial commands), but it doesn't acquire any lines in this mode. When I try this with the CameraFileGenerator I get a message with a timeout. When I try it with NI MAX, I get an error message stating no serial termination character is received.
Do I need to make changes to the .icd file? What changes? (edit: I tried attaching the icd file but it is rejected)
In the end I want to do the acquisition using LabVIEW (the galvo control also runs in LabVIEW).
Aart
05-09-2022 05:23 PM
Are you connecting the trigger to the 1433 or to the camera?
With camera link it should be connected to the 1433.
05-09-2022 05:36 PM
yes the trigger is provided to the little coaxial connector at the PCIe1433.
