Error -380205 when using RFmxInstrMX with ‘Simulated=1’
I wanted to simulate (i.e., not using the physical hardware) the device of NI PXIe-5840 Vector Signal Transceiver (VST). I executed the following command in MATLAB:
NET.addAssembly('NationalInstruments.RFmx.InstrMX.Fx40');
import NationalInstruments.RFmx.InstrMX.*;
InstrMXHandle = RFmxInstrMX(‘VST_01’, ‘Simulate=1,DriverSetup=Model:5840'); % This is where the error occurred
I got the following error message:
Error using NIRFmxDriver
Message: NationalInstruments.RFmx.InstrMX: -380205: An interaction with LabVIEW has caused the following error:
Error code: -380205
identifier: 'MATLAB:NET:CLRException:CreateObject'
Source: NationalInstruments.RFmx.InstrMX.Fx40
Below is the software I have already installed:
  1. NI RFmx SpecAn software
  2. NI-RFSG software
  3. NI-RFSG Playback Library software
I was wondering if I missed installing some required software, or the way I used the API was incorrect.
Any help would be much appreciated. Please feel free to let me know if you need more information. Thank you for your time and effort.
(2,073 Views)
How did you solve this problem?
(1,531 Views)
Accepted by chohsintsai
The issue can be resolved by installing RFmx Power Amplifier.
Thanks!
(1,506 Views)
