How to I create delays (seconds + Minutes) in BASIC program
I am tyring to generate timed digital outputs via my DAQ (NI USB-6229) and need to create some very simple timing under program control.
The delays are required to be 500ms to 3 sec.
I have tried using the Timer found in the toolbox but having trouble sending the correct parameters.
Could you please help.
- Panorama
(3,668 Views)
What version of Measurement Studio are you using? Have you tried the examples in C:\Documents and Settings\All Users\Documents\National Instruments\NI-DAQ\Examples\DotNET3.5 ? The 6229 should be very capable outputting data between 500ms and 3 seconds, depending on the amount of jitter that is acceptable to your program you could do this using a software loop.
Richard S -- National Instruments -- (former) Applications Engineer -- Data Acquisition with TestStand
(3,637 Views)
I specifically need examples of using a watchdog Timer in Measurement
Studio.
I am using Measurement Studio 2009 for Visual Studio 2008.
I need to trigger a watchdog timeout when program execution is taking too
long.
The on-line technical support only gives examples for LabView ... not
measurement studio.
Your help will be greatly appreciated.
Panorama
(3,624 Views)
The example is located here:
C:\Documents and Settings\All Users\Documents\National Instruments\NI-DAQ\Examples\DotNET3.5\Digital\Generate Values\WriteDigChan_WatchdogTimer
(3,607 Views)
