04-18-2016 04:40 PM
Hello!
I am using a 6052E card with DAQmx.
When I add the DAQmxCfgDigEdgeStartTrig function to my code to start data collection on a start trigger, I get the error:
-200077 Requested value is not a supported value for this property. The property value may be invalid because it conflicts with another property.
Here is the code block that I am using this function in:
char startTrigger[256]="Dev1/PFI0"; int startEdge=0;//rising edge DAQmxErrChk (DAQmxCreateTask("",&taskHandle)); DAQmxErrChk (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai0, Dev1/ai1","",DAQmx_Val_Cfg_Default,-10.0,10.0,DAQmx_Val_Volts,NULL)); DAQmxErrChk (DAQmxCfgDigEdgeStartTrig(taskHandle, startTrigger, startEdge)); DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,NULL,nFrequency,DAQmx_Val_Rising,DAQmx_Val_ContSamps, (m_nBufferSize*2))); DAQmxErrChk (DAQmxStartTask(taskHandle));
Any ideas what I may be doing wrong?
Thanks!
04-19-2016 10:32 AM
Hi Senkyoshi,
Do you have any other configurartion for the task that you haven't displayed?
Also, can try adding a leading forward slash to your stratTrigger string: "/Dev1/PFI0"
Kyle S.
Applications Engineer
04-19-2016 11:16 AM
Thanks for the reply ks30,
I do not have any other configuration for the task.
Also, adding a leading forward slash did not change the outcome. Still recieveing the same error.
-senkyoshi
04-20-2016 10:55 AM
Hi Senkyoshi,
Can you set your startEdge value to DAQmx_Val_Rising instead of 0?
I replicated your issue by doing the opposite so that should resolve it for you.
Kyle S.
04-26-2016 10:47 AM
So I found the answer to my problem.
I changed "Dev1/PFI0" for start trigger to just "PFI0".
Strange that this would solve the issue.
to:
char startTrigger[256]="PFI0";
