04-16-2015 11:16 PM
I have started using Visual Studio for ANSI C a few week ago. I am using NI cDAQ-9178 equipment, NI9227 module for current measurement, and NI9239 module for voltage measurement. I am trying to get synchronization work for 2 current channels in NI9227 (cDAQMod1/ai0: cDAQMod1/ai1) and 2 voltage channels in NI9239 (cDAQMod2/ai0: cDAQMod2/ai1).
I tried DSA Sample Clock Timebase synchronization. It doesn't work.
Here's the error message I get:
"DAQmx Error: Requested value is not a supported value for this property. The
property value may be invalid because it conflicts with another property.
Property: DAQmx_SampClk_Timebase_Rate
Requested Value: 80.0e6
Possible Values: 1.0e6 to 13.150000e6
Device: cDAQ2"
What does "requested value" and "possible values" mean? I don't have any
parameters in 80.0e6, is this some value in the system?
04-20-2015 09:37 AM
Hello;
It is possible that the task is not configured correctly. Can you post at least that section of the code so we can check it?
04-20-2015 12:21 PM
I used the example code from national instrument , I tried National Instruments\NI-DAQ\Examples\DAQmx ANSI C\Synchronization\Multi-Device\Finite AI, and \National Instruments\NI-DAQ\Examples\DAQmx ANSI C\Synchronization\Multi-Device\DSA Shared Timebase And Trig-AI and AO. They all end up with the same Error.
I did not change the code, except Device Name and synchronizationType. I changed synchronizationType to be 0 for Sample Clock.
Here's a part of code for DSA Shared Timebase And Trig-AI and AO:
DAQmxErrChk (DAQmxCreateTask("Master input task",&gMasterAItaskHandle));
DAQmxErrChk (DAQmxCreateAIVoltageChan(gMasterAItaskHandle,"cDAQ2Mod2/ai0","",DAQmx_Val_Cfg_Default,-10.0,10.0,DAQmx_Val_Volts,0));
DAQmxErrChk (DAQmxCfgSampClkTiming(gMasterAItaskHandle,"",10000.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,1000));
DAQmxErrChk (DAQmxCreateTask("Master output task",&gMasterAOtaskHandle));
DAQmxErrChk (DAQmxCreateAIVoltageChan(gMasterAOtaskHandle,"cDAQ2Mod2/ai1","",DAQmx_Val_Cfg_Default,-10.0,10.0,DAQmx_Val_Volts,0));
DAQmxErrChk (DAQmxCfgSampClkTiming(gMasterAOtaskHandle,"",10000.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,1000));
DAQmxErrChk (DAQmxCreateTask("Slave input task",&gSlaveAItaskHandle));
DAQmxErrChk (DAQmxCreateAICurrentChan(gSlaveAItaskHandle,"cDAQ2Mod1/ai0","",DAQmx_Val_Cfg_Default,0.0,2.0,DAQmx_Val_Amps,DAQmx_Val_Internal,249,""));
DAQmxErrChk (DAQmxCfgSampClkTiming(gSlaveAItaskHandle,"",10000.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,1000));
DAQmxErrChk (DAQmxCreateTask("Slave output task",&gSlaveAOtaskHandle));
DAQmxErrChk (DAQmxCreateAICurrentChan(gSlaveAOtaskHandle,"cDAQ2Mod1/ai1","",DAQmx_Val_Cfg_Default,0.0,2.0,DAQmx_Val_Amps,DAQmx_Val_Internal,249,""));
DAQmxErrChk (DAQmxCfgSampClkTiming(gSlaveAOtaskHandle,"",10000.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,1000));
04-20-2015 12:26 PM
Here's a the code of FiniteAI in an easier version:
DAQmxErrChk (DAQmxCreateTask("",&masterTaskHandle));
DAQmxErrChk (DAQmxCreateAIVoltageChan(masterTaskHandle,"cDAQ2Mod2/ai0","",DAQmx_Val_Cfg_Default,-10.0,10.0,DAQmx_Val_Volts,NULL));
DAQmxErrChk (DAQmxCfgSampClkTiming(masterTaskHandle,"",50000.0,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,1000));
DAQmxErrChk (DAQmxCreateTask("",&slaveTaskHandle));
DAQmxErrChk (DAQmxCreateAICurrentChan(slaveTaskHandle,"cDAQ2Mod1/ai1","",DAQmx_Val_Cfg_Default,0.0,2.0,DAQmx_Val_Amps,DAQmx_Val_Internal,249,""));
DAQmxErrChk (DAQmxCfgSampClkTiming(slaveTaskHandle,"",50000.0,DAQmx_Val_Rising,DAQmx_Val_FiniteSamps,1000));
DAQmxErrChk(DAQmxSetSampClkTimebaseSrc(slaveTaskHandle,"/cDAQ2/SampleClockTimebase"));
DAQmxErrChk(DAQmxSetSyncPulseSrc(slaveTaskHandle, "/cDAQ2/SyncPulse"));
DAQmxErrChk(DAQmxCfgDigEdgeStartTrig(slaveTaskHandle,"/cDAQ2/ai/StartTrigger",DAQmx_Val_Rising));
