04-25-2006 10:41 AM
04-26-2006 05:00 PM
05-31-2006 12:20 PM
06-01-2006 03:49 PM
Hi Kevin,
Modifying an existing example is a great way to start an application. It sounds like you are trying to use an analog trigger to retrigger an analog input operation. Would it be possible for you to either:
- use a digital trigger? This way you could use the digital trigger to retrigger a counter output operation and use the counter as the sample clock.
- continuously acquire your data and filter out unwanted data in post processing?
Hal L.
06-02-2006 01:39 PM
Before I try another approach I would like to understand the existing code.
The problem is that that this program only triggers 4 times per second.
