I'm using a NI-6008.
The sensor that I'm using, give me 0..1.5V in output and it's powered by
+5V of the 6008 so it share the same GND with 6008:
+5V
[SENSOR] -----out----> >--AI0
| >--GND
--- GND
In this scenario, must I configure input as RSE input?
(DAQmx_Val_RSE in NI-DAQmx) or I can configure input as differential
input (DAQmx_Val_Diff in NI-DAQmx)?
But, so doing, I can't use PGA to achieve full scale, since Gain=1 when
RSE inputs are used.
Is there any trick to force use of PGA also with RSE inputs?
Thanks in advance
