12-13-2016 07:36 AM
Hello
I am new to the NI GPIB concept. Currently I am working on an application which I am developing in VIsual C++ 2010 express with Windows Forms, using C++/CLI language.
I am using the NI4882.dll and try to use the NI4882 namespace. I have establish connection with my device but I cannot find a way to use other commabds except from read and write. Is there an example out there using the NI4882 namespace I can reference from ?
12-20-2016 02:59 AM
After installing NI-488.2 driver you can find some examples in this directory:
C:\Users\Public\Documents\National Instruments\NI-488.2\Examples
If you need simple / high level GPIB communication you could also use NI-VISA driver.
After installing you can find examples here:
C:\Users\Public\Documents\National Instruments\NI-VISA\Examples
Please make sure to also select "Development Support" including the "Examples" option in both installers, in order to install the examples mentioned above.
12-21-2016 12:10 AM
Hello Christian-P
That is what I was looking for .
Thank You
