Hardware configuration
I need to actuate the solenoids using Micro-controller and also have to acquire the data of the actuations and other pressure sensors on the screen using NI card.
Can I connect the two?
If yes how to do it?
Kindly help.
(2,247 Views)
Hi Omkar,
Sounds like you could use a NI DAQ card to meet your needs.  You could use the digital output (DO) to control on/off of your solenoid, then use the analog input (AI) channels to acquire data from your pressure sensors.  I would recommend you check out the Multifunction DAQ forum, it has more information on NI's DAQ cards.
-Jason
WPC Systems
(2,179 Views)
Hello Jason,
Thank you for your help.
I thought of using NI DAQ, but I have to use microcontroller and NI 9205 only. I can use LabVIEW to control MC, but can I connect or synchronize MC and NI 9205?
Please let me know. Thanks.
(2,165 Views)
