How to write to Kollmorgen AKD
have to set up a system that uses the following Kollmorgen components:
Servomotor AKM24D-ANBNR-00
Drive AKD-P00306-NBCC-E000
Motor (AKM13C-AKCNGD00)
I am interested in creating with LabVIEW an application to control the motor by sending a speed profile. I read that NI has very expensive software to communicate with these drives. So I want to use a solution with a PC and modbus (via ethernet cable) communication method.
The only code that works to communicate with the drive is attached. I can read the "588" parameter and get the position of the motor. I went through the parameter list and they have 1760 instructions but I have no idea which one can make it move (write) hence I have no way of sending motion profiles!!! Any suggestions? Does anyone have a basic code to make the motor move???
(4,538 Views)
Anon,
I see you received an answer to your question here: http://forums.ni.com/t5/LabVIEW/Kollmorgen-AKD-communication-with-Labview-Ethernet-IP-drivers/td-p/2...
Do you still need help?
(4,506 Views)
Thank you for your reply!
Yes, I do need help as I have specific hardware to work on.
I need to find a way to send instructions to the AKD drive, and more importantly the sequence of the instructions in order to make it move. I have a list via Kollmorgen with prameters & their registered addresses but I am not sure about the sequence to use and what to fill the registers! Its not as simple as just write a value like DAQmx and this is the first time I use Modbus.
Hence if you have an example it will be very helpfull!!!
It would also be nice to have the sequence to start/control the motion tasks.
Thank you in advance
(4,497 Views)
Anon,
I would recommend contacting Kollmorgen to find out more about the sequence; they may know more about this subject than what you'll find on NI forums.
(4,472 Views)
Thank you for the reply.
Unfortunatelly Kollmorgen replied (through te local dealership) that they dont offer support for Labview applications. Propably since they teamed with NI to create a suite that you pay to get, they dont offer free help.
If anyone even has experience calling and stopping the preprogrammed motion tasks please let me know
(4,439 Views)
I saw you mentioned Modbus in your initial post, are you looking for a way to do this using the Modbus library for LabVIEW?
A good option for you might be SoftMotion Lite. This is a free version of SoftMotion that you can use to implement straight line movements.
Aaron Douglass
Applications Engineer
(4,430 Views)
