I am using the Motion Assistant code generation tool to generate a simple single axis relative move in LabView.
In the Motion Assistant I can jog the motor CW or CCW, however it does not appear I have control over the rotation direction in the VI.
The LabView code works fine otherwise for all other parameters, I just need to be able to control the direction.
Can someone pointme inthe right direction?
Kevin
