Motion Control and Motor Drives
NI PXI 7340 : Motor starts and stops immediately, doesnt reach target value
Recently, i have upgraded OS in the PC. Max configuration has been restored. New drive has been configured in velocity mode. When i try to run the motor, start vi starts the motor but it stops suddenly after small movement. As per my code, i wait in wait for move complete. Timeout occurs after waiting for configured ( 16 secs) time. Motor doesnt reach the target value.
When run vi executes, i am seeing a value in analog output of UMI 7774. But it is not continuous. I need to get continuous value till i reach the target position.
I have configured PXI 7340 in custom mode where i will be able to set each axis configuration settings.
(1,587 Views)
From what this sounds like, I'm guessing the problem is a following error problem.  Have you tried these 2 articles?
Following Error in a Motion Control System
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z0000019Lk7SAE&OpenDocument=&l=en-US
What Is the Following Error in a Motion Control System?
https://knowledge.ni.com/KnowledgeArticleDetails?id=kA00Z000001DbLaSAK&l=en-US
-John
(1,556 Views)
I havent tried these . Will try and post
(1,549 Views)
How to fix the value for following error?
(1,529 Views)
