05-11-2011 07:49 PM
05-12-2011 02:03 PM
hey Carlos,
Here is a good starting point.
A. Zaatari
05-12-2011 02:31 PM
Dear A. Zaatari,
I don´t understand why the details of my post didn´t show up. Sorry.
In fact, I need to connect the PCI with the UMI, but the UMI is inside a case. So, I need to connect the PCI to a panel connector and then this connector to the UMI. I have doubts about this intermediate connection. How to do this? Which connector should I use?
On the other hand, I could use a cable to connect directly to another cable (from the UMI to the panel) attached to the panel.
I really appreciate if you could help me.
Best regards.
Carlos.
05-12-2011 02:44 PM
Hey Carlos,
I am still not sure what this intermediate connection is? Can you post pictures or part#? Is it something we sell, or was it custom made?
A. Zaatari
05-12-2011 03:06 PM
Hey Zaatari,
I am developing my product yet. As I told you before, I need a connection from the PCI to a panel of my product. And them, from the panel to the UMI. How to do this? I´d like to know which connector I should use. NI sell these parts?
Unfortunately, I can´t do a direct link using a single cable from the PCI to UMI.
Regards.
Carlos.
05-13-2011 05:50 AM
Carlos-
Why can't you go direct? Is it because of length, or just getting throught the cabinet? If it is length, I believe there is a spec for that, and it is pretty short. If it is getting through the cabinet, then I have used Roxtec sealing devices before. Depending on which Roxtec you use, you might have to take the shell off the connector to get it through, then put the shell back on.
Brian
05-16-2011 09:42 AM
Dear Brian, thanks for your message!
The problem is getting thought the cabinet. Could you send me more details about the solution with Roxtec you mention it?
Regards.
Carlos.
05-16-2011 09:46 AM
Take a look here: http://www.roxtec.com/
