Single Axis Move Example - where to get?
I'm using the Control Loop (Fixed Point PID) Library and I use it with an NI9514-Module to control Position and Velocity of a motor.
The SoftMotion-Help often refers to the "Single Axis Move (with PID and Velocity feedback) VI" and/or the "Single Axis Move (with PID Vff Aff) VI" which both should be located in " examples\Motion\SoftMotion\RIO" - but in my LabView Installation (LV2015 32Bit) with SoftMotion installed there is just the folder "examples\motion\SoftMotion\ControlLoop", containing the "ControlLoop PID(FixedPoint).llb".
I've tried installing LV2014 (includin SoftMotion) but could not find the example as well-
Is there somewhere I can download it?
Greetings!
(3,065 Views)
Hello jkkjhäpoiiutzdfysdtgzuijop,
the VI´s you are searching are in use on the FPGA side in the Servo Interface (9514).lvproj in the actual LabVIEW example finder ( search for 9514). This example go very deep into FPGA programming. You can easier use the moduls in hybrid mode and with softmotion API.
NI 9514 FPGA and SoftMotion
Hope it helps.
best regards
Alexander
(3,046 Views)
