Motion Control and Motor Drives
The version of the LabVIEW NI SoftMotion Module installed on the host differs from the version installed on the RT target.
Hi Eng.Tareq
Did you follow this step in order to create your application?
http://www.ni.com/white-paper/9566/en/#toc6
TuiTui
Message 12 of 19
(3,103 Views)
hi
yes i followed but i donno what is the problem
Message 13 of 19
(3,101 Views)
Hi Eng.Tareq
By looking at the document and what you are trying to do, You should be at step 4
Step 4: Deploying to Hardware (Optional)
Is this correct?
If this is the case, in the document there is a part written
The following additional hardware and software is required to complete the "Step 4: Deploying to Hardware (Optional)" section of this tutorial:
Software
• LabVIEW Real-Time Module 2009 or later
• NI-RIO 3.2.0 or later
Hardware
• NI CompactRIO controller and chassis that support the RIO Scan Interface
  or
• NI 9144 distributed chassis
• Two NI 9512 single-axis stepper drive interfaces
• Power supply for the controller
• A separate power supply for the modules
• Ethernet connection and cable
Even if you do not have the hardware used in this tutorial, you can follow the steps and perform offline configuration to learn about using CompactRIO with LabVIEW.
By look at the list of your software, I don't think you pass all the requiement
1.I don't see NI RIO in your list of software
2. Do you have labview Real-Time Module installed?
TuiTui
Message 14 of 19
(3,097 Views)
but i dont have any hardware
i just want to connest to solidworks
Message 15 of 19
(3,095 Views)
Hi Eng.Tareq,
Can you tell me which step are you upto?
And what have you done that the error shown up?
TuiTui
Message 16 of 19
(3,091 Views)
i added Solidworks model and axis
i want to deploy the project after this i got this message
thanks
Message 17 of 19
(3,088 Views)
Hi Eng.Tareq,
Adding the model and axis is in step 1 of this paper http://www.ni.com/white-paper/9566/en/#toc6
Have you do the configuration and create a motion profile which is step 2 and 3 in the paper
If you have done all the thing in that paper, can you post the VI so that i can investigate?
TuiTui
Message 18 of 19
(3,085 Views)
Hi Eng.Tareq
How is the thing so far?
TuiTui
Message 19 of 19
(3,067 Views)
