Motion Control and Motor Drives
multiple velocity inputs in a sequence of blended moves
I used the template 'Sequence of Blended Vector Moves' in order to synchronize two different motions on two different axes. I am trying, however, to input two different velocity vectors (one for each axis move) and can't seem to find a good way to input both of them as the velocity input only accepts a single input.
Thanks!
Lauren
(2,975 Views)
Hello laf3g,
Have a look at the attached LabVIEW VI. I duped the “Load Velocity in RPM” VI and allowed for the velocity specification of each axis. Give this a shot and modify accordingly. I hope this helps 🙂
Message Edited by DjDaveNI on 07-28-2008 06:56 PM
David G
Sales Engineer - SE Michigan & N Ohio
(2,961 Views)
