Hi Mushu,
You are using a
BNC-2110 with a
NI 6111. You can see in that file (or the
associated PDF) that there are some connections for various PFI lines on the top right side of the BNC-2110.
But what do those PFI lines do? That depends on the board.
So the best way to figure it out is to look at the pin assignments for
the NI 6111. You can find the pinouts in the
S Series Help. In there you will see that the pinout for the NI 6111 look like this:
From this image you can see that the following pins are associated with the lines you are looking for:
CTR 0 Source Pin 37
CTR 0 Gate Pin 3
CTR 1 Source Pin 42
CTR 1 Gate Pin 41
Lines P0.6 and P0.7 are only used when trying to read things like
Quadrature Encoders.
Best of luck with the rest of this,
Message Edited by Otis on 09-26-2005 02:52 PM
