07-31-2006 09:05 AM
08-01-2006 02:23 PM
outputs on card A with inputs on card B AND outputs on card B with inputs on card AORoutputs on card A with inputs on card A AND outputs on card B with inputs on card BI would like to replace that OR with an AND if possible.
08-01-2006 03:09 PM
08-01-2006 04:43 PM - edited 08-01-2006 04:43 PM
Message Edited by Garrett H on 08-01-2006 04:44 PM
08-02-2006 02:47 PM
08-03-2006 05:14 PM
08-04-2006 09:18 AM
08-04-2006 10:14 AM
08-29-2008 03:45 PM
I wanted to synchronize two PCI-6115 boards. I tried "Acquisition_problem_reddog_solution.vi" with LabVIEW 8.6, but got the error -200802.
The whole error message is below:
"Error -200802 occurred at DAQmx Write (Analog 2D DBL NChan NSamp).vi:3
Possible reason(s):
Measurements: Write cannot be performed when the task is not started, the auto start input to DAQmx Write is false, the Sample Timing Type is something other than On Demand, and the output buffer size is zero.
Call DAQmx Start before DAQmx Write, set auto start to true, modify the Sample Timing Type, or change the output buffer size.
Task Name: _unnamedTask<179> "
Do anyone know what is wrong with this VI? I connected my two boards with a RTSI cable.
Thanks a lot!
Geena
