04-02-2014 08:40 PM
How can you alter the Digital Out (PO.x) voltage for the NI 6343 (it is a DAQ)? By default it outputs 5V on high. I need 3.3V output for my application.
04-03-2014 06:21 AM
I recommend getting a buffer that can do the voltage changeover. Of course, you will need to supply a 5V and 3.3V to power the buffer, but that is the best way to go.
Another method I've seen is use a resistor and a 3.3V zener diode to bring the voltage down. This likely will cause you to lose bandwidth, so only try this if you are dealing with static digital outputs.
04-03-2014 09:10 AM
Thanks. Looks like this is not adjustable - possible idea for a future hardware update 😉
04-03-2014 09:27 AM
I wouldn't count on it. Not many DIO cards out there will output different voltage levels.
The other benefit of using a buffer is the extra current. Most DIO cards cannot put out much current (something like 2.4mA). Buffers will allow for a lot more. The buffers I typically use output up to 24mA. But there are some that will do a lot more current.
