01-07-2019 10:51 AM
Hi all,
I am a new user on the forum. I am Danilo an engineering student and for the first time I am gonna decide which kind of DAQ system I am gonna use for some measurements in the process that I am studying.
I am quite confuse about all the informations regarding DAQ system that is why I am writing here trying to see if I have understood same basic principles that I have to follow to choose the right DAQ system.
In my case, I am gonna use 8 thermocouples and a dynamometer to measure temperatures and forces in the process. In that case I think that I need a 16 channel DAQ that will allow me to measure all these quantities. Am I right?
Furthermore, as long as I have understood, I have also to check the sampling rate and to check the sampling considering that I am using several channel in the same time to be sure to acquire data in a satisfying rate for my application.
Let me know if I am on the right direction or if I am not getting the point of the DAQ system that I am looking for.
Thanks in advance,
Danilo
01-08-2019
08:59 AM
- last edited on
01-11-2024
07:53 PM
by
migration-bot
Hi Danilo
There are multiple ways to design your DAQ system to fit your requirements, and each of them has pros and cons. I see two main solutions here :
The choice will also depend on the budget you have available and/or the hardware you already have.
Thomas
01-08-2019 10:23 AM - edited 01-08-2019 10:25 AM
How fast do you need to sample each sensor?
What type (voltage/current/bridge/resistive/??, bandwidth) of other signal sources ?
For slow measurements (every 1s for temp for example) a multiplexed DAQ would work. BUT if you want to measure more dynamic signals don't use I wouldn't use a single multiplexed device and mix up TC voltages (µV range) and process signals in the 10V range.
I would use one or more DAQ devices for the TCs (slow , multiplex possible) and synchronious sampled multichannel DAQ(s) for the rest. The C-Series modules 9214 (16 ch TC) and a 9202 or 9215 or ?? for your other sensors.
Get a chassis with one or more spare slots ... new challenges with new sensors might come.
