CB-68LPR Connector
Dear NI,
Can you please let me know what 68 pin connector (make and model) you use in the CB-68LPR breakout board. I realize that you have a similar styled connector listed (TE Connectivity 2-5174225-5) on one of your document pages (https://www.ni.com/en-us/support/documentation/supplemental/15/ni-daq-device-custom-cables--replacem...), but the board side connections are not compatible between these two models (rows a and b are swapped). I have created a board that models the pinout of the connector you use in the CB-68LPR and so I would like to purchase the same connector. Please advise.
Best,
Taylor
(588 Views)
This article lists the 68-pin VHDCI connector that NI uses
https://www.ni.com/en-us/support/documentation/supplemental/19/right-angle-vhdci-connectors-p-n-7789...
Santhosh
Soliton Technologies
(553 Views)
Hi Santhosh,
Thanks for the link. I believe those are what NI uses internally in their ADC/DAC cards, which is a VHDCI connector. The one on the CB-68LPR isnt a VHDCI, its another, but incompatible D shaped connector.
Best,
Taylor
(549 Views)
