Multifunction DAQ
Can the pci-6111 capture 400,000 samples
Accepted by topic author rocksolidsr
Hi rocksolidsr,
I'll admit it's not the most robust sub-vi...
The waveform graph needs to be for a single channel.  The instance of DAQmx Read you are currently using is N Channels N Samples.  If you change the DAQmx Read (via the drop-down box underneath the function) to be Analog >> Single Channel >> Multiple Samples >> Waveform, the code should work.
-John
John Passiak
Message 11 of 12
(919 Views)
John P I can't thank you enough, it works great. thanks again for all your help
Message 12 of 12
(915 Views)
