Multifunction DAQ
Common low in Differential Mode: Urgent
Hell forum,
I have a situation where I cannot use RSE connections due to noise considerations. So using my USB 6212 I have attached 8 of my sensors in differentiaL mode with the return line common to all 8 AI(-) inputs and is a reference sensor. i am using 100 kohm bias resistor on all AI(+) lines as well on ALL AI(-) lines. Is this correct? I mean since the AI(-) lines are common to all, should I be connecting only one 100 kOhm?
I am thinking since I have connected 8 bias resistors on a common line shared amongst all AI(-), this effectively reduces the bias resistor to much lesse value (parrallel connection).
Please advice 🙂
cheers,
(3,006 Views)
navneet,
Yes your set up is correct, you need bias resistors on all lines. The following document covers this well.
Field Wiring and Noise Considerations for Analog Signals
Danny F
Danny Funk -- Senior Group Manager -- Software R&D -- NI
(2,986 Views)
Thanks Danny for your reply. ut it still buggers me if I connect all 8 bias. Since at any given time when any of  the switch is connected, it will "feel" 8 bias resistors connected since this one line gioes to each of the 8 AI(-) inputs! I think this will be redundant and can be accomplished with only one bias resistor? Please see attahced file for scheme.
(2,977 Views)
Accepted by navneet
navneet,
If the AI- lines are all connected to the same node on your measurments, then yes you can use only one bias resistor.
Danny F
(2,946 Views)
