09-01-2021 11:42 AM
Jerry_X, some mistake in the math, still 14 slots x 4 channels results in only 56 channels and OP will be short of 8 channels.
09-01-2021 02:14 PM - edited 09-01-2021 02:19 PM
Doh, you are right! I don't know why I think 14 * 4 is 64, not 56. Maybe I didn't drink enough coffee this morning. 😅
In that case, to meet the channel requirement we will need 2 cDAQ-9179s and 2 NI 9469s (sync module). Using the sync module allows cross chassis synchronization which allow the user to put all the AI modules in the same DAQmx AI task, and DAQmx will take care of the all the synchronization on the backend.
09-01-2021 03:47 PM
Does DAQmx channel expansion work across different cDAQ chassis or does the user has to maintain task per chassis and configure the sync?
I know that DAQmx channel expansion works across PXIe chassis with the Timing&Sync option.
09-03-2021 03:39 PM
DAQmx channel expansion work across different cDAQ chassis in 2 cases
Then the user can have a single DAQmx task containing all the modules from different chassis.
