Connecting NI PCIe-6321 to custom PCB
Hi y'all,
I am designing a custom PCB to interface between our sensors and our NI PCIe-6321.
1- Can I use an unshielded cable to make the connection? We work with low frequency signal (less than 100 kHz) Shielded cable will cause some trouble as all will enclosed in a tight space.
2-What kind of receptor should I use on the PCB to interface with the cable (RC68-68)
Thanks!
Fabrice
Best regards!
Fabrice
"If Locals are Duct Tape, then Globals must be toilet paper" Greg Bush
(4,539 Views)
Hi!
1. You can probably use an unshielded cable, although you may experience issues with RF noise. Shielded cables don't take up that much more space, is there a reason you need that little extra bit of room?
2. The cable terminates in a SCSI-II female connector.
(4,523 Views)
Accepted by topic author FabriceMTL
Hi Fabrice,
This document contains all of our multifunction DAQ board mating connectors.  You're going to want to check out the 68-Position 0.050 Board Mount Connectors section under Connectors and Backshells for the SCSI connectors.  You can get either the right angle or vertical mount option from our website or from a 3rd party vendor.  (We provide the part number in that document if you want to buy it elsewhere.)
David R
Systems Engineer
(4,513 Views)
Thanks Chantastic and Roohcifer for your replies.
Chantastic, I have to be able to fit a motherboard + acquisition card + the custom build PCB in a very tight volume (7x9x4in). Using a shielded cable will be a trouble because I won't be able to bend them enough plus the shortest avaible is still too long.
Best regards!
Fabrice
(4,485 Views)
