Multifunction DAQ
Connecting Omega PX309-10KG5V pressure transducer to SCXI 1520
I have an Omega PX309-10KG5V Pressure transducer that operates between 0-5V and requires a 9V excitation (http://www.omega.com/Pressure/pdf/PX309-5V.pdf).
I am having trouble getting the transducer running on my SCXI box with a SCXI 1520 card. I think I should be using custom voltage with excitation. I am not sure what I am missing.
Any help is appreciated.
Thanks!
Message 1 of 8
(5,304 Views)
floydie83,
How are you trying to create a task, through MAX? LabVIEW? SignalExpress?
What problems are you running into specifically?
Rob W.
Message 2 of 8
(5,280 Views)
Thanks for the reply. I am creating the task through MAX. I cannot get the gage to read. I am setting the task up as a custom voltage with excitation. I am putting the red into P+ and black P-. White goes to S+. I am not sure if that layout is 100% correct. Maybe I'm missing a jumper?
Message 3 of 8
(5,258 Views)
Are you able to run the task in MAX or do you get an error? What kind of data are you receiving? Can screenshot it and share it?
Rob W.
Message 4 of 8
(5,215 Views)
will do this afternoon! Thanks.
Message 5 of 8
(5,207 Views)
Okay, I hope I have the wiring correct. I am attaching two pictures that show the wiring to the SCXI 1314 and the settings I am using in MAX.
The transduce requires 9-28 V of excitiation. The gage just reads 0V or 5V depending of the direction of the wires. Am I missing a jumper?
Thanks again.
Message 6 of 8
(5,198 Views)
Also the scale is just a linear 1 to 1 scale currently.
Message 7 of 8
(5,196 Views)
Im not sure if you meant to attach the same picture twice, but could you attach screenshot of the Task running in MAX and the data that you receive when the task is running?
Rob W.
Message 8 of 8
(5,169 Views)
