11-06-2014 05:43 AM
Hey,
I am connecting USB6343's onboard 5v source to AI 4 5 6 7 through 4 switches (and AI GND). This results in floating signals and sinusoidal noise when i close the switches and not the expected 0v / 5v.
I merely want to report on or off for each switch connected to the AI terminals, what very obvious step am I missing?
11-06-2014 06:59 AM - edited 11-06-2014 07:04 AM
A 10k-100k pull down resistor from AIx to AIGND 🙂
Have a look in the manual about voltage measurement and input bias resistors.
And if you look into the manual at page 6-23 you see how to do that with a DI , here with a pull up resisitor (same value range) and a switch to GND.
05-18-2015 10:25 AM
I'd like to do the same thing (reading a switch on a USB-6343) and had the same idea as Henrik_Volkers, but am confused, as the manual also says (page 3-4):
Caution Never connect the +5 V power terminals to analog or digital ground or to
any other voltage source on the X Series device or any other device. Doing so can
damage the device and the computer. NI is not liable for damage resulting from such
a connection.
In my low understanding of electronics this is a contradiction to page 6-23, where it shows that a +5V power terminals is connected to DGND, as soon as the switch closes. Would somebody be so kind to explain what I'm getting wrong?
05-18-2015 11:00 AM
Look at the diagram a little closer on 6-23. There is a resistor in series with the +5V before the switch. This resistor limits the current going into the digital input, preventing any damage.
05-18-2015 12:04 PM - edited 05-18-2015 12:05 PM
I hope it's okay to add another more or less stupid question? Is my assumption correct, that I need a resistor with min.20 kΩ, as on page 8 of the specifications of the USB-6343 it says:
Digital I/O Characteristics
I_IH input hight current (V_IN=5V).....................250µA
05-18-2015 01:03 PM
That 20k is the minimum built-in pull down resistor in the daq board. You need to make sure there are at least 2.2V going into the pin of the daq board to ensure it can read a high level. So I would use something more like a 10k resistor to act as the 5V series resistor (about 3.3V will be going into the DAQ based on 5V, 10k series, and 20k pull down).
05-19-2015 08:42 AM
I'd like to ask further questions, but being new to the forum, I'm not fully familiar with the customs, so please tell me if I should open a new topic or if it's okay, to bundle questions (if related).
The question are: how to extend the described wiring to multiple switches (I need 10)? I attached my assumption as "Wiring 1.png".
And I guess "Wiring 2" wouldn't work as it'd be how the topic-opener artaxerxes did it?
