11-30-2010 06:42 PM
This is my first post so please excuse the quality of my description.
When I double click on the DAQ- Assistant block, there is no connection diagram tab that I can access to see how things are wired up. I have a NI USB-6211 connected through USB and it is used to control many different sensors and a power supply. It currently works for everything and is hard wired correctly but only one of the DAQ-Assistant blocks has a connection Diagram available the other do not. The one with a connection diagram is used to monitor a voltage. The others that do not are used to generate a signal. I would really like to be able to see the connection diagrams for every block.
-Any help would be much appreciated
-Thankyou
12-01-2010 10:44 AM - edited 12-01-2010 10:45 AM
Hello fushionhokie,
Connection diagrams are only available for Analog Input tasks. If you have questions connecting your signals using the Analog Output channels, please feel free to let us know 🙂
Ali M
Applications Engineer
12-01-2010 02:57 PM
12-01-2010 09:13 PM
You could always do like the ones that never use the DAQ Assistant and read the manual. Right clicking on the device in MAX and selecting 'Device Pinouts" also works.
