Multifunction DAQ
Connection a load cell with Ni 9949 to Ni 9237
Hi everyone,
I am trying to connect a load cell, full bridge, to the Ni 9237 using a Ni 9949... I have conecting the wires as  describe in the manual specification of the Ni 9237 [ Ex- (7) ; ex+ (6); In + (2) ; In- (3)].
What happens is, When I try to read the load cell using either MAX or the DAQ Assistant in LabVIEW, I always get the same output value ( 25mv/V), having or not  applied a load to the load cell.... Anyone knows why is it happening?
Thank you,
BR ,
Ana
(5,080 Views)
Hi Ana,
What kind of bridge configuration did you choose?(Half or Full bridge?)
Do you use an internal or external excitation voltage and at each level?
Paolo_P
Certified TestStand Architect
Certified LabVIEW Architect
National Instruments France
(5,036 Views)
HI Paolo,
I choose a full bridge configuration.... I am not using an external voltage... I select internal voltage with 10V ... I still not working.. you have any idea why ?
Thank you
(4,945 Views)
Are you sure the load cell is working? Do you have any other load cells or units you can test with the same configuration?
(4,912 Views)
