Multifunction DAQ
Is PCI 6601 rev 184479E-02 compatible for 3.3v PCI-X bus
Upgrading my process control server, and 5 volt PCI slots will not be available.
The 6601 in the current server is 5 volt slot only.
My spare 6601 has two slots in the bus connector, revision 184479E-02.
Need to know if it's 3.3v slot (PCI-X) compatible for the new server.
Also, will 5 volts still be available on J1 of the Interface Terminal Block (CB-68LPR)?
I'm using that on the open collector of my optical isolation.
(3,555 Views)
Hi BWatt,
You can tell that the card is PCI-X compatible because it has two notches. For more information you can look at this Knowledge Base. Regarding your second question, the 5 V power source, supplies the power from the computer’s power supply, so I understand you should have no problems. I hope this is helpful,
Ana P
(3,529 Views)
Buen dia tengo el siguiente problema, con este mensaje,.
Driver task ci02- versin 0.15
No  Ni -DAq Mx Tasks available
File modul -CI.C,line :685
por lo tanto no responde, el lab wie
(2,962 Views)
Hi rubenvw,
Because this thread is no longer active, you may have better luck starting a new thread for your issue. We even have a forum where you can post where you can ask questions and receive help in Spanish, if that’s the language in which you feel most comfortable- http://forums.ni.com/t5/La-Comunidad-en-Espa%C3%B1ol/ct-p/ESAForum.
As for the error you’re receiving, when you create your new post, be sure to include the error number, and any information you have about when and where the error occurred. Including a snippet of the smallest version of your code that produces the error is always a good idea, too.
Kathryn K.
http://ni.com/support
Kathryn K.
Technical Support Engineer
(2,949 Views)
