Multifunction DAQ
Continuous sampling of unbuffered ports
I'm trying to use a USB6356 device to sample a set of digital signals continuously (until the user presses a stop button) but when creating the task I get a warning that say ports 1 and 2 don't support buffered operation. I guess this means that I can only acquire a predefined number of samples.
I have thought of creating a loop with feedback nodes and this way retrieve one sample at a time from each channel and save these samples in an array but here I face the problem of timing, as the smallest delay I can set for the loop is 1ms (so the largest sampling rate would be 1KHz).
Any ideas about how I can overcome this?
Cheers
(3,768 Views)
Accepted by thehun
The device has only 8 pins that are hardware timed (port 0) and with software timed acquisition, the MAX rate is around 1kHz. You should get a better card if you need higher rates for that many pins.
(3,759 Views)
Thanks, I guess I will either need to reduce the number of signals and send them all to port 0 or get a new card.
(3,752 Views)
