07-29-2011 12:02 AM
컴퓨터와 DAQPAD-6070e 간의 연결을 firewire(1394)로 하게되어있는데 연결이 쉽지 않습니다.
드라이버를 설치하여 LabVIEW의 장치자동검색 창 목록에 나타나도록 할 수있는 방법이 있을까요?
07-29-2011
04:29 AM
- last edited on
06-28-2024
03:17 PM
by
Content Cleaner
Hi
I am not sure that I understand your problem, but for using DAQPAD-6070e and Windows compatibility I would recomend you to check out the following link
https://www.ni.com/en/support/documentation/supplemental/08/archived--traditional-ni-daq-and-daqmx-d...
Hope it will help you.
09-20-2011 09:24 PM
Thank you very much. .
But, the result makes me harder. :manmad:
