Multifunction DAQ
DAQmx 50103 error, two MAX tasks on E-series board
A bit of a puzzlement here, even after reading all of the posts on the infamous -50103 error.
I'm debugging a data acquisition task, in LabWindows/CVI, for a PC with an E-series PCI board (PCI-6032E, I think). There are two analog channels: one is a photosensor ("Receiver") that is read in bursts, the other ("Power") is a power meter that is read occasionally. I set up two tasks in MAX, with the appropriate timing and trigger settings; load them in my program using DAQmxLoadTask() and such, and off we go. Where I run into problems is when I need to restart the "Receiver" task and re-allocate the buffer according to some run-time settings. When I do this, the DAQmxStartTask() call fails.
If, as I understand, the problem is that you can't have two concurrently running tasks on the same board, then why don't I get the -50103 error when I first start up the two tasks?
The basic sequence looks like this:
Init()      //called once at start of program to init both tasks
                DAQmxLoadTask(&Receiver_handle)
                DAQmxSetTrigAttribute(&Receiver_handle)
                AllocateBuffers()
                DAQmxLoadTask(&Power_handle)
                DAQmxSetTrigAttribute(&Power _handle)
                AllocateBuffers()
InitTask(&handle)             //called to stop and restart the Receiver task with new buffer settings
                CloseTask(&handle)
                                StopDAQ(&handle)
                                                DAQmxStopTask(&handle)
                                DeallocateBuffers()
                                DAQmxClearTask(&handle)
                DAQmxLoadTask(&handle)
                DAQmxCFGInputBuffer(&handle)
                DAQmxRegisterEveryNSamplesEvent(&handle) //register data handler (receiver task only)
                AllocateBuffers(&handle)
StartDAQ(&handle) //called once for each task, called again after call to InitTask()
                DAQmxStartTask(&handle) [fails]
The program successfully calls StartDAQ twice initially, and starts each of the two tasks without error. I only get the -50103 at the DAQmxStartTask () call the second time I call StartDAQ() for the receiver task, after stopping, reallocating buffers, and re-loading the task (which happens without error). Any help greatly appreciated.
(3,288 Views)
Hi pblase,
In the tutorial Causes of NI-DAQmx Error -50103 "The Specified Resource is Reserved" I think your situation falls under Case 7: Failing to properly clear a task and release its resources. I think if you use the DAQmxClearTask command or similar to release the resources, you will not get that error. You see other example codes that you can reference here.
Daniel REDS
RF Systems Engineer
Help us grow.
If a post solves your question, mark it as The Solution.
If a post helps, give Kudos to it.
(3,235 Views)
Yes. It is not immediatly clear that you can't run two tasks at the same time on the same board; I rewrote the code so that I'm running one task with two channels.
(3,227 Views)
Accepted by pblase
     I hope you had a wonderful holiday season,   looking at your code I am thinking that we need to make sure you have only one task running,  below  I think would be the best way to initialize the task at hand and see if it works.
DAQmxErrChk (DAQmxCreateTask("",&taskHandle));
DAQmxErrChk (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai0","",DAQmx_Val_Cfg_Default,-10.0,10.0,DAQmx_Val_Volts,NULL));
DAQmxErrChk (DAQmxCreateAIVoltageChan(taskHandle,"Dev1/ai1","",DAQmx_Val_Cfg_Default,-10.0,10.0,DAQmx_Val_Volts,NULL));
DAQmxErrChk (DAQmxCfgSampClkTiming(taskHandle,"",10000.0,DAQmx_Val_Rising,DAQmx_Val_ContSamps,1000));
   If that does not solve your problems I would check the example finder and see if any of that code is able to help you out.
   Lastly I would have both channels sample data at the same rate and then if you have too many samples on one line you can throw away most of those samples.
I hope that helps,
Daniel
(3,201 Views)
