12-07-2016 04:36 AM
Hi All.
In the current project which I am working on, I need to acquire data from Analog input of DAQ card, I am trying to use DAQmx vi to create a task at one place of the code and do the DAQmx read based on certain conditions, since DAQmx read requires Task in as reference I have wired the task out which got generated from "Daqmx create virtual channel vi" .
The problem what I face is "task out" when connected to indicator shows empty (but when I proble the task out wire I see "_unnamedTask<..>")and Daqmx read eventually gives me an error.
I understand that if I have everything at one place vi works properly and I get what I need.
But for the above mentioned piece of code I am finding issues.
Pls guide
12-07-2016 06:09 AM
Post your code so we can look at it. Otherwise it is a complete shot in the dark about what could be going wrong. And what error are you getting?
