11-29-2016 02:07 AM
i am measuring a voltage using the NI9223 and log the data to a tdms file. Since my signal processing takes a lot of time, i try to read the tdms file while the measurement is still active.To do this, I modified the "Concurrent Access to TDMS file" example.
Unfortunately the TDMS Read VI always responds wit a error:
LabVIEW: End of file encountered.
NI-488: Invalid argument or arguments to function call.
I already tried different offsets and data lengths (-1) but nothing seems to work.
Thanks a lot for your help
Solved! Go to Solution.
11-29-2016 05:28 AM
DAQmx has exclusive access to the TDMS file during the logging process. That is one of the reasons it can log data faster than a Producer/Consumer.
For your exact example, you should be using the Log And Read mode and use the DAQmx Read inside of the loop to then write to your chart.
